I am glad to be in this great place.My problem sounds like this:I instal a fresh copy of windoes x SP3 (Format,install,etc) i install my motherboard,audio,video,lan drivers,i install software wich i comonly use . All goes well for a wild but from some time now this happens,i start my pc,it boots,the welcome blue screen apears as usual,dektop apears as well my antivirus (Avira) and my other protction iobit malwarefighter start to,then i go to the green start menu and i want to go to conect to...for internet conecting,the green start button freezes and i cant acces it anymore,sometimes it takes even 3 minutes to get up and runing again,my pc is powerfull,both ram and cpu,so i dont know why this happens ? My wndows xp its not original
but i have never had this problem before,once i had a windows xp black edition and did not had this problem,but at Start--->Startup----> had a thing called something like WINDOWS XPSLOWBOOt(STARTUP)FIX.VB that helpful but in the classic windows xp this thing cant be found,where can i find this thing to download,whats the problem,how and what to stop freezing !
AVIRA
IOBIT MALWARE FIGHTER
IOBIT ADVANCED SYSTEM CARE
IOBIT SMART DEFRAG
Are some siftware i use incase it helps in my problem !
Thank you and sorry for my bad english im from romania !
AVIRA
IOBIT SMART DEFRAG
