Hello all. I came to get help with XP but as I was registering I was told my email was already in use but I get nothing when I try to reset. It is possible I joined at some point in the past and forgot but I'm not seeing that.
I used a different email to get it done and I am not sure if I had not joined sometime in the past for a moment.You show as a registered user so not seeing a problem.
You need to use cloning software. Either 32bit or 64bit Depending on what operating system you have installed. You also need to know if it is NTFS or FAT32.I used a different email to get it done and I am not sure if I had not joined sometime in the past for a moment.
Anyways, I really would like to know what is THE BEST way to clone an old 2002 XP drive C. What type of imaging software should I use for such an old program and hardware? Our old HP desktop is still functioning and I want to properly save its essence
I am used to Macrium Reflect, but I don't know what version or a good place to get. Old Versions has a 5.1 version that someone suggested. This PC was upgraded and updated to the end of support for XP. Service pack 3.You need to use cloning software. Either 32bit or 64bit Depending on what operating system you have installed. You also need to know if it is NTFS or FAT32.
There are many types of cloning software. A quick perusal on the internet thingy will come up with loads.
My personal favourite is Ghost, a quite old program, but I have never had a problem with it. One needs to put the file on a disk with an operating system and then clone the separate disk onto an image file. One can then clone this onto as many different disks as needed.
Here are the 32bit and 64bit versions on my server.
Ghost This is all You need.zip
Some links below, for some instructions.
https://www.cybernetman.com/kb/article/how-to-create-a-bootable-usb-with-ghost64
https://knowledge.broadcom.com/external/article/171757/how-to-perform-disk-to-disk-imaging-usin.html
I am sorry I don’t have experience of Macrium Reflect. All I can do is give you advice on software I have used and know IE Ghost. I uploaded the software for you, I put a link so that you could download the full version. I know it works on XP, Win7, Win8, Win10, Win11. I uploaded and provided you a link with both the 32bit and 64bit version.I am used to Macrium Reflect, but I don't know what version or a good place to get. Old Versions has a 5.1 version that someone suggested. This PC was upgraded and updated to the end of support for XP. Service pack 3.
Macrium Reflect 7 (Free home version) tested on XP SP3 32bit.I am used to Macrium Reflect, but I don't know what version or a good place to get. Old Versions has a 5.1 version that someone suggested. This PC was upgraded and updated to the end of support for XP. Service pack 3.
That is one detailed guide. Is there a free version that works on Windows 10 still? I have 8.1 and it is not free anymore.Macrium Reflect 7 (Free home version) tested on XP SP3 32bit.
Macrium.7.2.4473.32bit.FREE.XP
MediaFire is a simple to use free service that lets you put all your photos, documents, music, and video in a single place so you can access them anywhere and share them everywhere.www.mediafire.com
The contents of the ZIP file:
MacriumRescue.7.2.4473.PE.3.1.32bit.XP.iso - the bootable rescue media created by Macrium in this guide.
v7.2.4473_reflect_setup_free_x86.exe - the actual setup program.
I agree with @Madeleine Takam, you're better off creating an image and restoring from an image to the new drive rather than direct cloning. The image can be kept on removable media as backup in case of hard drive failure.
1) Creating an image of your drive is exactly like that, like nothing ever happened.I've only accidentally seen how a clone will be picked up on by the PC and booted up like nothin ever happened. I liked that.
