Drivers for sound card
Hi
Have an inbuilt sound card into the mother board, but Device Manager is showing question marks; please see the attachment. Just installed service pack 3 and no differance
Any help please?
Thanks
Most likely the driver you're looking for is (or was) on the DVD that came with the motherboard.
If that DVD got lost in the fogs of the past (as it normally happens), the driver is probably still available for download on the manufacturer's website (have ready the MB version/ID number/model/whatever).
If you don't find it there, then you'll better brace yourself for a damn long frustrating search on the Internet Archive - but if you're stubborn enough in the end you'll probably find it :)
Yes the CD must of been with the original owner of the computer, and now lost at sea:)
But the good news is I know the motherboard is a ASUS PTGD1-LA(Puffer M-UL8E)
And the manual can be found hear https://theretroweb.com/motherboard...-mul8e-user-manual-6717d765bef20499832142.pdf
Just wonder where I would get the CD for it?
Then it's going to take some patience but there's still hope: for instance a 10-second search for "ASUS PTGD1-LA drivers" took me here. While I cannot guarantee that the link proffered there is really the one you're looking for, at least that's evidence that your driver still exists and someone else needs it too.
Unfortunately today I'm having a rather busy day, but I'm sure you can manage a thorough search by yourself. Just be careful: the internet is full of sharks and not all that glitters is gold (short for "run everything you download through a trusted AV before installing it").
Good luck!
Good luck!
I dont understand it! I mena i though you needed it on CD and you booted the CD from when you start the computer. I did however download the one in the link you supplied and installed it hear on win XP. and it found the missing programs but wants to charge £8.05 for it! So they must be a 3rd party, surly the manufatures would have it somewhere for free to download right?
Let's start over.
What kind of computer do you have? Laptop/desktop/tower case? Name Brand?
In Device Mgr., when you expand "Sound, Video, and Game Controllers", what is installed?
Have you tried removing the Unknown Devices with the question mark, and rebooting?
Since you say your MB has onboard audio, I'm assuming you have speakers hooked up to the outputs, and you're not muted or at low volume?
Let's start over.
Its an old motherboard out of some PC, with sata IDE and RAM 1 and stuff
I uninstalled the question marks in device manages like you said and the error dissapeared! However I then rebooted, and they came back again
There are 2 sets soldered to the motherboard, one a 3.5mm set of colored out put jacks of plugs. and the other 2X phono jack out puts
Thanks
You don't need the physical CD/DVD: an ISO image of it (what you usually download) will do. And you don't need to boot from it: all you need is a small program (e.g. WinMountPortable) that "mounts" the ISO image - that is, that makes it visible to the system as if it were a real physical drive.
At that point you just locate the autorun and run it.
that program wont download!
though cnet went under years ago?
That's the driver. download and install. It is a universal driver. It might work. You probably won't need yje advanced settings unless you want to do fancy recording.
You mean the one in the image that I have attached?
BTW it wont run!
What does Device Mgr. have listed under Sound, Video, Game Controllers" ?
(I would play with RealTek settings if installed)
