Yes it’s all very confusing, as everything does seem to go well during installation without any errors popping up. When saying that neither driver worked I’m referring to the fact that the system does not discover any devices once all is installed. There are several Bluetooth devices in the Lab, printers, door locks and a few other custom in house systems none of which are detected during the discovery process.
And as I mentioned before, I had gone through all the trouble of loading Windows 10 on the Lab computer in question, same hardware, motherboard and Bluetooth adapters and every device was detected. I was able to pair each device and communicate with them. The only problem was that I had to revert back to XP in order for our custom built software to run. However it wasn’t a complete waste of time loading Window 10 as it showed that the hardware is indeed compatible proving the Bluetooth devices in the Lab are working and able to connect using either one of the adapters.
So back to the XP box, yes I have a Bluetooth icon in the taskbar and confirmed that Discovery is on but when I try and add a device none show up. The system waits for a moment while searching, and that’s when I can see the adapter’s Blue LED turn on before it comes back saying No New Devices Found.
The BlueSoleil software asked if I wanted to remove the Medium level Security so insure all device would be discovered but it didn’t seem to help. The system simply doesn’t detect any Bluetooth devices. Below is the actual prompt:
“Your security level is 'Medium' now. Other Bluetooth devices must provide a Bluetooth passkey before connecting with your computer. If you do not want to have security authentication, uncheck 'Use security level Medium'”
I actually tried it both ways, one with the security set to Medium and one without.
As for purchasing a new Bluetooth adapter compatible with XP, well that's exactly what I did, I ordered it the beginning of the week.
Here are the properties shown for the Amazon Bluetooth adapter compatible with XP
Address: 00:1A:7D
A:71:13
Here are the properties of the Abe Bluetooth
Address: 00:0C:78:33:9D:70
Cambridge Silicon Radio
HCI Version: 1.2
HCI Revision: 7A6
LMP Version 1.2
LMP Sub Version 7A6
