Hmmm... Just ran both the Supermium Setup and NonSetup files through "https://www.virustotal.com/gui/home/upload" scan. Both reported to have imbedded Trojans.
Has anyone managed to get the V.13.7b installed and running on win XP?I started having issues with Mypal 14.7b a few weeks after the upgrade. At first I was very happy with it, but now it not only loads very slow, but when ever it’s running all other programs also load very slow and exhibit delayed responses to any interaction.
I’m not sure exactly how to diagnose the issue, so I figured I would first go back to V.13.7b after completely purging everything “Mypal” from the system.
Is this purge as simple as deleting directories and registry entries, or could Mypal also be affected by other browsers on the system? (Serpent, Firefox, Chrome)?
Also, if there’s any way to keep profile settings that cannot be part of the problem, that would be very helpful. Bookmarks are easy enough, but I’ve never figured out an easy way to save individual settings for allowed cookie storage and such.
Thanks for any input,
Wolf
r any input,
Wolf
Yes, I ran that version of MyPal for a long time, but saw many websites eventually not load, or appear incorrectly as sites altered their security and/or other elements. From there I experimented with several newer releases, but faced the same issues or some unexpected performance issues with the "improved" releases.Has anyone managed to get the V.13.7b installed and running on win XP?
So basicly it would not run with the new HTML5Yes, I ran that version of MyPal for a long time, but saw many websites eventually not load, or appear incorrectly as sites altered their security and/or other elements. From there I experimented with several newer releases, but faced the same issues or some unexpected performance issues with the "improved" releases.
So you are saying this one will work are you and load all web pages?At the moment, I'm using MyPal V.78.0.2 (32 bit / non SSE) for almost all my browsing, switching to 360Chrome for only those rare sites that won't load properly.
To get all the NOT Portable versions of MyPal installed and running, you simply extract the contents of the Zip file into a directory of your choosing ("C:\Program Files\MyPal"), and then create a shortcut to the MyPal.exe file in that directory. At first run, it will create two "MyPal68" directories under "C:\Documents and Settings\User\Application Data" & "C:\Documents and Settings\User\Local Settings\Application Data".
These created directories store all the profile information. If they already exist due to a previous install, then they will be over-written by the newer program, or you might get an error if you attempt to run an older version of MyPal with newer profile directories at those locations.
There are a few "Portable" versions of MyPal available where the program files and all the profile data are stored in a single location.
I have not had a browser installed on Windows XP Pro 32 that loads ALL web pages since I think FireFox 52.9 ESR,So you are saying this one will work are you and load all web pages?
There are 2 32bit versions on there
mypal-78.0.2.en-US.win32-sse.zip
mypal-78.0.2.en-US.win32.zip
Do you know which one to go for?
What are the source codes for?
Thanks
I just check and my new motherboard wont take my wifi card. since I am running on wifi at the moment, I will have to leave it until the 20th of this month when the data runns out on this card then buy a VodaFone card to run on my VodaFone USB DongleI have not had a browser installed on Windows XP Pro 32 that loads ALL web pages since I think FireFox 52.9 ESR,
The SSE version is supposed to be faster for SSE enabled CPU's (which I think even Fred Flinstone has), but I found the NON SSE version working better on my box.
You don't need the source codes.
If it's a NEW MB, then it probably has an onboard wifi adapter, for which you would just need the correct XP driver.I just check and my new motherboard wont take my wifi card.
