Switches are communicating at 10GB. Next piece will be the Chelsio card. I have the card, I've got some modules on order (they're expensive AF!).
The issue with the switches not communicating had nothing to do with the jacks (though they state they are rated as CAT6, and I don't think they were CAT6A), I had confused two wall jacks.
I found this out even after having switched the wall jacks out with ones specifically rated for CAT7, which were expensive. Unfortunately, while the CAT7 jacks appeared to be of good quality, they were quite defective/flawed in design. Plugs going into the jack never seemed to make good contact, and the tooless crimping of wires were also not making good contact.
