XP wont start up
Discussion in 'Windows XP General Discussion' started by Gordon, May 29, 2017.
  1. Gordon
    Gordon
    Had my computer powered down for the weekend. Came home to start it and it won't get pass the window XP screen.
    This is the window that shows the processing bar a little more than half way down screen.
    I have restarted windows many time and it still won't load.
    All I want to do is get it to start up so I can copy my "document" file.
    Is there a way I can get windows to load?????
    Gordon
  2. Gordon
    have you tried safe mode??
    restart (press crtl + alt + del to get task manager) or if you have to do a hard restart and when it restarts immediately start tapping F8 and choose safe mode, if you can get to this then you can copy any document.
    you can also boot to a rescue disk either hiren's boot cd of puppy linux to get access to your harddrive, go into bios and set pc to boot from the cd drive first.
    You may also want to run checkdisk:
    http://forums.whatthetech.com/index.php?showtopic=102348
    How to perform checkdisk
    go to start, run, type in cmd
    type exit and press enter
    Elizabeth23, May 30, 2017
