XP won't hibernate or standby -AVG Tune up
Discussion in 'Windows XP Hardware' started by Brian Astell, Apr 13, 2018.
  1. Brian Astell
    Brian Astell
    This is a recent problem.Sometimes PC will not close down at all, and now won't do a Hibernate or Standby mode.Just stays on. I must confess that this is all part of problems with AVG Tuneup. When installed it seemd VERY keen to put EVERYTHING to sleep -Firefox would not open, Photosync.remained dead.Have had 2 sessions with AVG support lasting about an hour each (!) while they got my PC back to "normal", but still the shut-down problem. I dread having to go back to AVG yet again.Anyone else had AVG tune up problems and regret buying it? Can anyone hlp me on this? I am hanging on to XP for as long as possible!
  2. Brian Astell
    Elizabeth23, Apr 13, 2018
  3. Brian Astell
    Brian Astell
    Brian Astell, Apr 14, 2018
  4. Brian Astell
    http://forums.whatthetech.com/index.php?showtopic=102348
    How to perform checkdisk
    go to start, run, type in cmd
    in cmd type in chkdsk c: /r and press enter NOTE: space between k and c, also between : and /
    type exit and press enter
    sorry for the late reply, I check the forum often but I did not catch your post, :)
    Elizabeth23, Apr 16, 2018
  5. Brian Astell
    Brian Astell
    Brian Astell, Apr 16, 2018
  6. Brian Astell
    chkdsk c: /r
    type exactly like above, your screen image shows chkdsk cr
  7. Brian Astell
    Vineet Garg
    Hi All,
    Greets,
    Sir(s),
    "Anyone else had AVG tune up problems ?"
    @Brian Astell : Sir,
    1. Yes it's problematic like many other so called Auto Tune Up/ Optimizer Softwares. The worst part of them is Registry Cleaning,Repairing &Optimization. Microsoft also offered Registry changers but discontinued long back !
    2. Didn't you make a system image of the stable system ?
    Thanks & Regards. ...
    Vineet Garg, Apr 20, 2018
  8. Brian Astell
    Vineet Garg
    Hi Brian Astell,
    Greets,
    Sir, Did you try reinstallation of Chipset , then Storage & then Graphic drivers ? It solved my problems once with " no stand by & no hibernate " !
    Vineet Garg, Apr 26, 2018
  9. Brian Astell
    Brian Astell
    Thank you for reply.I would need a lot more detail -don't understand your solution -I am not an IT scholar -but 81 and willing to learn. Brian
    Brian Astell, Apr 28, 2018
  10. Brian Astell
    Vineet Garg
    Hi Sir,
    Did you follow Mam Elizabeth23 ?
    Can you get me the model, make,etc. ?
    Vineet Garg, Apr 28, 2018
