XP SP3 desktop icons rearrange after reboot
Discussion in 'Windows XP Help and Support' started by JohnDohe, Aug 26, 2013.
  1. JohnDohe
    JohnDohe
    Machine: XP SP3, IBM NetVista, with all latest updates.
    AVIRA antivirus
    Programs loaded: MS Office Pro 2010, Client Access Express (allows pc to communicate
    with an IBM AS400 via 5290 communication; this has been there for over 10 years and
    this problem started about 6 months ago), MBAM, Adobe Reader, QuickBooks 2013
    Premier Plus Pro, Roxio 2010, RoboForm, Lexmark Printer Optra T616 drivers, DYMO
    Turbo 330 label printer drivers, OEX, Remove Duplicates from OE, Unlocker, and a
    couple more utilities that I don't THINK could be the problem, but ya never know ...
    I've had this problem of my desktop icons rearranging after a reboot both before and
    completely reinstalling XP SP2 and then downloading all the updates and updating to SP3
    and reinstalling all the above programs. System was fine for a few days, then the same
    problem came up.
    Suggestions?
    I've gone into the registry, renamed Desktop to DesktopOLD, rearranged my desktop
    to my preference, rebooted, and all the icons were in even worse order. I then deleted
    the newly created Desktop from the reboot, renamed the DesktopOLD back to Desktop,
    rebooted, and the icons went back to their previous dis-arrangement, but this was better.
    Anybody else run into this and come up with a solution?
    Thanks!
  2. JohnDohe
    here are 3 threads, read all and see if the solutions work for you:
    http://www.winhelponline.com/blog/fix-desktop-icons-layout-not-saved-restart/
    http://pressf1.pcworld.co.nz/showthread.php?115923-Desktop-Icons-Rearranging-by-themselves
    http://forums.cnet.com/7723-6142_102-328230/desktop-icons-rearrange-themselves/
    post back if these helped.
    I would also run the following just to be sure:
    Elizabeth23, Aug 26, 2013
  3. JohnDohe
    You should also check on the utilities you run and see if there is a setting that arranges your icons.
