XP Sort options
Discussion in 'Windows XP General Discussion' started by Nick1995, May 22, 2014.
  1. Nick1995
    Nick1995
    i have recently noticed something weird with an XP desktop i am using at the moment. It does not sort folders by alphabetical order and file types at the same time.
    Any1 knows what is the issue? Just a little note, this problem only happens to my desktop and not other desktops in the office running XP as well.
  2. Nick1995
    http://www.askdavetaylor.com/winxp_folder_directory_files_sorted_alphabetical_order/
    read and try above if not try the ones below:
    Restore Sort order in Open and Save dialogs
    http://www.dougknox.com/xp/scripts_desc/xp_opensaveorde...
    Or...
    To resolve this behavior, reset the default sort order:
    1. Right-click Start, click Explore, and then click drive C.
    2. On the View menu, click Details.
    3. Click the Name column to sort items by name, press and hold down the CTRL
    key, and then quit
    Windows Explorer by clicking Close in the upper-right corner of the screen.
    4. Release the CTRL key.
    5. Restart your computer.
    NOTE: You must perform these steps exactly as they are listed. For example,
    do not quit Windows
    Explorer by clicking Exit on the File menu.
    From...
    Items in "Open" and "Save As" Dialog Boxes Sorted Incorrectly
    http://support.microsoft.com/default.aspx?scid=kb;EN-US;Q229070
    Try this:
    Open a folder, make the arrangements you want.
    Click "Tools" / "Folder Options".
    Click "View" / "Apply to All Folders".
    A confirmation message should appear, click "Yes".
    Click "OK" to exit.
    Elizabeth23, May 22, 2014
  3. Nick1995
    Nick1995
    Tried
    hi there! thanks for the reply, i've tried these methods but it does not seem to work.
    What i want is actually for xplorer to sort my files by type and alphabetical order at the same time.
    Meaning, All file folders first(Name of folders from A-Z) followed by text documents(Name of Text docs from A-Z) as well
    When i tried it my folders names go from Z-A and when i click it again it does not sort by any order
    Nick1995, May 23, 2014
  4. Nick1995
    Hmmm, mine does this already all folders are a-z and inside of folders is a-z.
    now my temp int file is z-a by choice, I can click on the column header and change back to a-z.
    you might want to run some scans on your pc to check for malware:
    what is your current antivirus??
    Elizabeth23, May 23, 2014
  5. Nick1995
    Nick1995
    s
    Hi, sorry for late reply. its a mcafee/norton i'm not so sure as the computer does not belong to me.
    Seems now that the main problem is that all file types are able to be sorted except for folders type which doesn't seem to be sorted together.
    Nick1995, May 26, 2014
  6. Nick1995
    Nick1995
    anti virus
    Hi, sorry i just checked and the antivirus is MSE.
  7. Nick1995
    Elizabeth23, May 26, 2014
