the cd can be used to install on any pc, the trick is that you must have a valid license.
you can look on the side, or on the bottom for the 25 digit key, that will tell Microsoft that the installation is legitimate.
you cannot install professional on a home edition pc.
If you put the cd in the cd drive and choose explore you can read the files and see if it is an OEM cd.
