XP Monitor Driver
Discussion in 'Windows XP Drivers' started by jms, Mar 27, 2014.
  1. jms
    jms
    I’ve just bought a new Dell U2414H monitor, which hasn’t come with a XP Driver, and I get a warning notice every time I start my PC (Dell Dimension 8400). I’m a complete PC novice, so I asked on the Dell forum for help and advice, just to be told by the moderator “There is no Windows XP support for our newer monitors such as this U2414H. Dell only provided a Windows 7/8/8.1 driver. The U2414H User's Guide also only references Windows 7/8/8.1.”……some help.
    This is no way to run and business and stay in business.
    Can anyone please give me some advice of how I can get a driver or do I really need one, to a point, the monitor works fine, apart from the warning notice.
    jms, Mar 27, 2014
  2. jms
    you could get an acer, or one that still supports xp, but for drivers if Dell does not have an xp driver, then you are stuck with that message and can just disregard it.
    I see Chris is helping you at Dell, so you have a few choices, one to return it, two to just keep on using it and ignore the message, buy one compatible with xp.
    I have a monitor that is for win7 and says no input whenever I restart, but the monitor works so I just go on. :)
    Elizabeth23, Mar 27, 2014
  3. jms
    GeorgeSagu
    I dont know but try Driver Booster by IObit
    GeorgeSagu, Apr 12, 2014
  4. jms
    pravin007techno
    see their will be drivers for dell dimension try to download from net and install graphic drivers which may resolve your issues. hope so, once try these.good lucky
    pravin007techno, Aug 23, 2014
  5. jms
    Dashing star
    mauritius
    Dashing star, Feb 4, 2015
  6. jms
    Aunty Jack
    Aunty Jack, Feb 6, 2015
