"Wireless Switcher" error following installation of dotNET v4.0
On a Sony Vaio VPCW111XX netbook, running Windows XP Home SP3, I installed dotNET Framework v4.0. The installation completes successfully, but subsequently shutting down the computer results in a dialog box with a message about something called a "Wireless Switcher" which must close and the option to "End Now". This happens EVERY time the computer is shut down and is very irritating. Restoring the computer from a backup image to the point immediately before installing dotNET v4.0 cures the problem, so it is definitely related to this update. Any ideas, guys ?
go to start/shutdown/ look at the dialog box does the shutdown have a little shield icon?, this means that you have to shutdown and not restart after a .net install, and there are many .net updates have you updated over at microsoft updates?
Also look in event viewer , are any errors prevalent to this issue?
Automatically Close Applications Not Responding at Shutdown
To Implement for All Users
[Start] [Run] [Regedit]
Registry Key: HKEY_USERS\.DEFAULT\Control Panel\Desktop
Data Type: REG_SZ [String Value] // Value Name: AutoEndTasks
Modify/Create the Value Name [AutoEndTasks] according to the Value Data listed below.
Value Data: [0 = AutoEndTasks Disabled / 1 = AutoEndTasks Enabled]
Exit Registry and Reboot
To Implement for Individual Users
Registry Key: HKEY_CURRENT_USER\Control Panel\Desktop
HKEY_LOCAL_MACHINE\System\CurrentControlSet\Control
WaitToKillServiceTimeout and
HungAppTimeout and
change AutoEndTasks to 1 in the value which enables all process to be ended, 0 value will let processes take 20 seconds to end.
I have mine set to 1000, each 1000 is a second
Thanks so much for the reply - much appreciated.
Will try to re-install dotNET v4.0 in a few days and check registry entries that you suggest. Meantime, staying with the computer running dotNET v3.5 as I also have a second partition running Windows 7 with dotNET v4.6.2
I don't recall whether there was a shield icon next to the shutdown option, but I did shutdown (not restart) multiple times and the same problem occurred each time. Funny thing is, I also installed this dotNET v4.0 on a desktop computer which is not online and so hasn't been updated since basic install with SP3 and had no issues. Will let you know how I get on. Thanks again !
