Wireless connection
Discussion in 'Windows XP Networking' started by Tim Matarrese, Mar 17, 2017.
  1. Tim Matarrese
    Tim Matarrese
    I have dsl , when I connect a wired connection on my laptop I get connected to the internet, but wirelessly it won't connect, what's the problem?
  2. Tim Matarrese
    name brand, model and model number would be helpful as you might need a wireless driver.
    Elizabeth23, Mar 18, 2017
  3. Tim Matarrese
    Tim Matarrese
    Sorry, hp pavilion dv5000
    Tim Matarrese, Mar 18, 2017
  4. Tim Matarrese
  5. Tim Matarrese
    EthanStark
    restart the laptop Asked to turn on the Wi Fi and try to connect to the network. open IE and search for www.msn.com but its.open internet settings, clear the browsing history, Turn off the Pop up blocker, ensure that all LAN settings are proper.open IE but issue persist. With guest’s permission reset the IE and asked him to restart the laptop. Turned off the popup blocker in internet settings and guest try to search for www.yahoo.com , able to connected ?
    Regards,
    Ethan Stark
    EthanStark, Jun 19, 2017
  6. Tim Matarrese
    mikeyb
    .,.and disable your ethernet connection
    mikeyb, Jul 2, 2017
