windows xp with dual monitor, 2 separate background without running explorer.exe
Discussion in 'Windows XP Customization' started by nat, Jan 23, 2014.
  1. nat
    nat
    Hello,
    how can I use windows xp with dual monitor and have separate background for each monitor without running explorer.exe and web desktop?
    thank you,
    nat
    nat, Jan 23, 2014
  2. nat
    nat
    or is this even possible?
    nat, Jan 23, 2014
  3. nat
    Elizabeth23, Jan 23, 2014
  4. nat
    nat
    I don't want to use web tab and not allowed to use third party app...
    the web tab option wont work when I have explorer.exe disabled
    yes I need to disable explorer.exe.
    nat, Jan 23, 2014
  5. nat
    Sorry, but every site I check says either 3rd party app or using the Web tab.
    So, to my knowledge it cannot be done.
    Maybe someone else might have an idea.
    Good Luck. :)
