Windows XP wifi connexion problems
Discussion in 'Windows XP Networking' started by Lameen, Nov 29, 2013.
  1. Lameen
    Lameen
    Hi everybody
    I have problem with my Windows XP Wifi connection. By editing the register as asked by Windows troubleshooting this line is missing:
    HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet001\Services\DHCP
    How to solve it.
    Thank you.
  2. Lameen
    Elizabeth23, Nov 29, 2013
  3. Lameen
    Lameen
    Hi Dear
    I've installed it as described in your reply, but infortunately it doesn't work. When newly installed the line (HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet001\Ser vices\DHCP) is visible in the registery, but the connexion doesn't come back. When the system is reboted, the line desappears again in the registry. As you I have xp pro.
    Help me! Thank you.
    Lameen, Nov 30, 2013
  4. Lameen
    do the following please:
    msinfo32
    also expand the components/network/adapter and paste that info also.
    answer the following please:
    are you using any utility other than windows to search for wifi connections?
    if using windows you have to have the Wireless zero configuration service set to automatic
    http://support.microsoft.com/kb/968682
    above is microsoft page with fix it to do this automatically.
    also try to install the registry key in safe mode
    and also in registry ensure you right click on key and give yourself permission
    post back with info
    Elizabeth23, Nov 30, 2013
  5. Lameen
    I should have asked this first did you try a system restore to a point where your registry key was still installed.
    DO NOT USE ANY REGISTRY CLEANERS!!!!!!
