- Aug 9, 2022
Greeting!
My pirate insulation disk is a bit scratched so I though I should get another OS disk
There are many sold on ebay as new or used and new by way of still in the packet
unsealed! But they all say no product key! And they can not tell me if they will work with
out one. The disk I have dose not require a key, but what about the other ones? are there
disk out there that do require a key?
And if so then dose anyone know how to crack the code. win-95 is simple. the first 3
number can be anything and the last 7 number must equal 7
Thanks
As the OS is no longer supported. And the creators of this product say that it need to be
supported for it to fully function. then is it not abandoned software? and no longer falls
under copy right law?
Thanks
