What is the fix MS pushed to me 12/10/2014?
I am extremely leery of instilling this fix. The fix they sent a few weeks ago broke all of my software that depends on IE 8. That is, my HP scanner, Quicken 2014, Outlook Express, and anything that used IE 8 for help functions stopped working.
Will this new fix fix, or will it break some more stuff?
Clicked power-off instead of standby. So the damn thing installed. No Idea how to find the kb number.
If MS makes my XP machine unusable I swear I'll get a Mac before I succumb to Windows 8.
any thing installed can be found in the add/remove programs box, click the box on top to Show Updates , you can see updates installed it the event viewer, go to start/run, and type in eventvwr.msc and event viewer will open, you only need to worry about applications and system, you can click on either one in the left hand pane and the right hand pane will display the contents, there will be blue icon information, yellow icon warnings, and red icon errors,
updates and installations will be information unless one failed to install and then it will be logged as an error.
you can right click on each directory in the left hand pane and choose to clear all entries, and save them if you so choose, I clear my event viewer each day so I can see what is going on each day.
kb numbers are appended to the end of each listing for microsoft updates in add/remove
in event viewer the kb number is listed in the body of the message
Thanls Elizabeth23,
Here is what I found:
Microsoft ,NET Framework 3.5 SP1 (KB2604111) Last Used on 7/1/20145
Under this there is:
Update (KB963707)
Hotfix (KB958484)
Security Update (KB2736416)
Hotfix (KB953595)
Security Update (KB2861697)
Security Update (KB2840629)
Should I delete the master entry, or just specific fixes?
if you can find one that was installed at the time that your issues started occurring then you could uninstall that particular update.
but as no new updates have been issued since april 2014, I am curious as to how you got an update notification at this late date.
The updates arrived just after there were news stories about an ancient security flaw in Windows. That was June of this year. I presume that is what they addressed. My problem is I'm on Windows XP. I can't upgrade IE past IE 8. My guess is If I could upgrade IE, my problems would go away.
Interestingly, Quicken 2014 at least partly healed itself. Help is still busted across all products.
I'd probably have to replace my motherboard to upgrade to Windows 7. (Windows 8 is hateful.) This also means I'd have to upgrade all my software. So I'm looking at a coupla' thou I just don't wanna' spend.
you do not want to use IE unless the program just will not work on any other browser, you should install firefox, or chrome, I use firefox myself, IE is just there for some office 2003 training courses that will not work on firefox because they need an active x component.
I have the same exact updates installed on my pc, I do not use quicken , but you might want to uninstall and then reinstall, as for any thing requiring help if you have for example firefox, set as the default browser, then it goes to firefox .
I have no problem with help on any program.
do you have another browser installed??
is ie8 set as the default browser??
you should install another browser and also run checkdisk
How to perform checkdisk
go to start, run, type in cmd
type exit and press enter
If I may also suggest, the Updates service is only ever used by M$ and it takes up resources.
Turn it off.
