I was either thinking a 64gb cf card with a sandisk adapter since those seem to be the more reliable ones. There’s a sd card on my laptop tablet but that isn’t as safe since I’m planning on using it as a tablet. I’ll think I’ll buy a 32gb cf card and go from there.The maximum seems to be 512gb, but I'm not sure how much a PCMCIA slot supports. I'd suggest just to pick up the amount of storage you need and just hope it supports that much. Or else just get a portable harddrive.
Sounds good!I was either thinking a 64gb cf card with a sandisk adapter since those seem to be the more reliable ones. There’s a sd card on my laptop tablet but that isn’t as safe since I’m planning on using it as a tablet. I’ll think I’ll buy a 32gb cf card and go from there.
