VBSCRIPT Debugging
Can anyone please point me in the direction of either a free VBSCRIPT debugger or the location whereby I can download Visual Studio Express that supports XP as this has an IDE which will perform the debugger functions presumably. I have tried getting the older versions from MS but failed to load, I think 2012 supports XP although I may be completely wrong. Many thanks in advance
Visual studio 2010 was the last to work on xp/vista
Elizabeth23, thank you very much for your prompt reply, I have tried the 2010 VS and that worked OK, WindowsXPforever thank you for clarifying that point for me it has helped enormously. Eliizabeth23 the freeware from Novell is not available at the momemt but will try and report back. Thanks all for your help
