Unicode format
Somehow the Unicode format in my xp computer was replaced with ANSI format . So now I can't save any document with Arabic letters , even programs that have Arabic word in it's opening screens have been changed into some unreadable Latin letters . Also all notepad files that have Arabic words have been changed.
How can restore the Unicode format back ?
http://www.google.com/#sclient=psy-...53,d.eWU&fp=5cf50f12fa9815db&biw=1024&bih=561
google search page for ANSI / Unicode.
1. did you download anything new prior to this issue?
2. have you scanned for malware and spyware?
3. what is your current antivirus?
4. Have you system restored to a point where this was not occuring?
5. does this occur in safe mode?
7. have your run checkdisk?
go to start, run, type in cmd
type exit and press enter
restart pc, allow checkdisk to finish and run again.
8. and this:
msinfo32
post back with results
Edit: if you find a solution in the CNET forums please post here if any of the above solutions do not work, thanks.
