- Apr 14, 2025
Thank you for the idea! Will check it out!You could use DVD Decrypter's success.wav, it's quite cheerful without being annoying!
You were right, I didn't have it. Thanks for the zip!In case you didnt already have it
Please inform me how much RAM you can afford here: https://www.xpforums.com/threads/how-much-ram-do-you-have.935420/
You're welcome! You can also try out storageCheck if you want![]()
Session on 2025-06-12 14:00:52
Average RAM used by Windows processes: 53.81 MB
Average RAM used by other processes: 390.54 MB
Samples: 38
Session on 2025-06-12 14:05:37
Average RAM used by Windows processes: 36.14 MB
Average RAM used by other processes: 441.08 MB
Samples: 15
Great tool - Thank you very much.![]()
How do we install your program?If you have been reluctant with testing due to worrying about disorganized .exe files, worry no more! First build is out!
This is what the AV will look like, but with more modules. Might also add an installation option that removes the "No antivirus" pop-up (it needs to be done during install, requires GUID generation etc.).![]()
Release Build Beta 1.0.0 - Ready app · Martingonn/SentinelXP
The first application build, ready to use! No installation! Please tell me if you encounter any bugs - drop that info here, send it to [email protected] or in this XP Forums thread: https:...github.com
Please tell me any problems that you had or changes that I should implement!
Portable, no installation. Just unzip and run menu10.exe, then run some modules from there. All you need to do is unzip and run the menu.exe file.How do we install your program?
Could you please blur your IP out if you can? For example, in MS Paint - just cover it with some non-transparent color. The screenshot would be really useful for further development of the module.Yes, I do connect to the internet but nothing in red just black and white. I'd take a screen shot but it shows my IP.
Very nice toolAlso, I would really appreciate if you kept an eye on this: https://github.com/C0m3b4ck/SentinelXP/releases (my new repo, same scripts and all)
I just made two new modules, development is supercharged. Would be glad if you guys gave me some feedback on them.
Callhome Console: supposed to check incoming/outcoming connections https://github.com/C0m3b4ck/SentinelXP/releases/tag/beta_callhomeconsole_v1
Fortifier - disables ports/configs/etc. that allow for XP exploits: https://github.com/C0m3b4ck/SentinelXP/releases/tag/beta_fortifier_v2
Thank you very much! I will add support for 6 more exploits (mostly buffer overflow and port exploits), as with the rest, I will need to code custom kernel patches, which will be really time-consuming.Very nice tool
