I'm going to install XP 64-bit onto a computer using nForce (GeForce 8200).
I can switch to IDE mode in the BIOS, and will initially install the XP Pro 64 SP2 that way, and then install the nForce driver to get SATA ability.
Will I be able to do this reliably and have the computer use SATA mode correctly, even if it installs in IDE mode?
I already checked and most of the device drivers seem to work with XP 64-bit, so that's a good thing
Thanks.
Thanks.
