This is a query is about backing up XP.
I am presently recovering from a h/w failure and had to install a 2nd box which was already operable, but not complete.
The previous box had XP and for backup on that I used Faststone Driveclone 5 (despite it's age and limitations) and it worked very acceptably for all desired features; both for images and snapshots on & off the PC's HDD.
Now that it is time to re-install I am taking another look at what seems as good.
These are the ones I am considering:
Driveclone 5 (again);
Keriver 1-Click;
FirstDefense-ISR (yes, I still have it...);
Drive Snapshot;
ShadowProtect.
My goals in this effort:
1.
To have a full image backup on a separate HDD as well as a fully cloned system kept on standby in case of HDD failure.
2.
Snapshots kept on the in-use HDD (but hidden) for use in the event that roll-back is needed for any reason.
3.
At least one pre-boot option to restore snapshots.
4.
The ability to use alternate boot media to restore fully if needed.
There is only one serious complication=>
Besides the NTFS system partition it also has a FAT16 partition with a minimal OS as well as BartPE as a boot option.
(This PC does not have Linux on it.)
As a result of the multi-booting scenario I have ruled out the following:
EAZ-FIX;
Lazesoft products;
Comodo Time Machine.
I did consider the new AX64 and a few others (Acronis, Paragon, etc...) but found that those already mentioned are closest in features and are either ones I already have or consider affordable.
Using them in tandem is also a consideration.
I seek opinions as well as suggestions for which of these things coexist well together based upon actual experiences from fellow XP users here.
Thanks !!!
Keriver 1-Click;
Drive Snapshot;
ShadowProtect.
1.
2.
3.
4.
EAZ-FIX;
Lazesoft products;
Thanks !!!
