Problems since MS stopped support of XP....
Discussion in 'Windows XP Help and Support' started by wmn, May 2, 2014.
  1. wmn
    wmn
    calif
    Attempting to log-on to Windows I get, 1) "Enter current Password". I do that, it is accepted, then, "to Begin click your User name".
    The problem is there IS NO USER name shown. I cannot get to control panel, to even REFORMAT with the XP cd. The logon never completes.
    What is up?:confused:
    wmn, May 2, 2014
  2. wmn
    Jojo
    This place, sadly, doesn't seem very active.
    The easiest way since you obviously have access to a working machine, is to download a copy of Hirens Boot CD, burn it to a cd and use that as a live OS to fix your problems.
    I have tried to post some url links but I'm not allowed to yet.
    Enter Hirens Boot CD in Google and download the file. Burn it to a CD.
    Before you start do a youtube search for videos on removing the admin password using hiren's Boot CD. There are loads on the Hirens and this subject.
    Try this as a search
    Hiren's really is an essential piece of kit.
    Needless to say, make sure you know exactly what you're doing before you start. And Good Luck
    Jojo, May 2, 2014
  3. wmn
    Courtesy of Jose Ibarra
    http://www.imgburn.com/
    cmd
    chkdsk c: /r
    Elizabeth23, May 2, 2014
  4. wmn
    Jojo
    Good to hear from another Hiren's user. :)
    Jojo, May 3, 2014
  5. wmn
    WMN1
    According to the manual on the format of Windows XP, I must be able to re-log on to my existing version 0f X.P.. What if I cannot do this?
    HEREIN LIES THE RUB... Since I can only access the Bios after putting in my password, I still cannot complete a boot. Therefore I cannot complete a boot from the HD, CD, or floppy without a name to go with a password. I have three computers, an XP pro Dell, an AsRock w/XP home and a Win7 laptop Compaq. I have a fair amount of experiance with Windows, from the onset of 95 through all the versions of the Windows OS's. This has got me stumped. I'm pretty sure this is the last of MS for me, Never even had a virus until MS cut the support of XP. I have repaired a few and built two from scratch. Assuredly, I am not expert though.
    I have changed my boot process to all combos, yet, all return to , "to Begin click your User name"! The problem is there IS NO USER name shown.", so there is no name to click on.
    I am 78 years old but not stupid or uninformed. I asked for assistance and evidently the replies (so far) do not understand. If I cannot boot to my HD, CD, Floppy, but only to the Bios, How the heck can I format XP? I have already removed the Battery for a minute or two ( as per another suggestion), and still the same problem. BTW, The HD, CD, Floppy are all recognized, but unavalable!
    Delivery to the following recipient (XP forums) failed permanently:
    Technical details of permanent failure:
    Google tried to deliver your message, but it was rejected by the server for the recipient domain xp forums.com by mail.xp forums.com. [50.22.235.65]. The error that the other server returned was: 5 50 Requested action not taken: mailbox unavailable or not local
    WMN1, May 3, 2014
  6. wmn
    Jojo
    Sorry WMN I didn't realise the problem was with your BIOS password.
    There are means of bypassing the BIOS password. I confess I have never used one.
    https://www.youtube.com/watch?v=9aslVZsiYdw
    Or I may be mistaken, are you assuming that you can only access the BIOS from Windows?
    If so, that is not correct. The BIOS is accessed by repeatedly pressing a key, on my computer it is DEL, as soon as you switch on. Keep pressing till the screen says you are entering BIOS or startup.
    Once in your BIOS, the actuasl method of changing your start up sequence varies upon which BIOS you use.
    Mine is Phoenix for example. Like most, I need to select the appropriate page and scroll down to the BOOT priority list. Set the DC/DVD to first.
    Though before you do anything, you should try loading from a CD/DVD since most BIOS are already set to BOOT from CD/DVD drives first.
    If that is not clear please get back to us.
    Addition.
    Another option that `may be a bit silly, since you have never seemed to be stupid or illinformed. Have you tried, when asked to click a name, simply pressing ENTER?
    Your descriptions are not very clear, but your most recent suggests you may simply have the computer set to ask.
    Jojo, May 3, 2014
  7. wmn
    If you did not put a password on your BIOS did then someone else did, did you take it to a shop??
    If it came with a bios password from the manufacturer, then you will have to go to that manufacturers customer support to get the password
    there are 3rd party programs that will help break a password, but I believe it is not legal and the programs are probably full of malware
    what is the make, model, and model number of the pc you need the bios password for and I will see if I can find a number for you.
    were you ever able to enter the bios before this time??
    Elizabeth23, May 3, 2014
  8. wmn
    Elizabeth23, May 4, 2014
