then I woould run checkdisk to ensure that all is well, if your installation cd is at sp3, then you can insert it restart, and choose R at the setup menu and run chkdsk c: /r
let run till finished, if your installation cd is not at sp3, then burn a copy of Hiren's boot cd and run checkdisk from there.
Courtesy of Jose Ibarra:
http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
http://www.hirensbootcd.org/burning/
Instructions
http://rufus.akeo.ie/
http://www.hiren.info/pages/bootcd-on-usb-disk
Hiren’s for flash drive
