Hello,
This is my first post on this forum.
My apologies if I have selected the wrong sub-section.
Anyway, I have just re-installed XP-Pro on an old Sony laptop model VGN-S3HP.
Everything is working correctly.
I want to use it with an Acer projector, model P1206. I should mention that
before the re-install it worked fine with this projector.
But now I cannot get any image to display on the projector -- the projector scans
all its ports then always says No Signal.
I am sure the cable is OK, because when I restart the laptop with projector
connected the initial Windows opening screen is briefly correctly displayed.
I have used the control panel display panel to search for driver updates, but
after a long search it reports that installed drivers are up to date. There is a
CD with the projector, but no drivers on it.
Can anyone offer any advice? Many thanks, Ken
