I'm wondering which e-mail program would be the best replacement for O-E?
Which one do any of you-all prefer?
Thunderbird seems to appear at the top of most lists I run across, , , ,
-corne-
I have been using yahoo for all the time
Can you like not say 'autism galore'? I'm somewhat autistic myself...Sadly yahoo is now owned by "Oath" even the name is to fool you into presuming something respectable.
these guys are data molesters of the highest order, ZERO sentimentality
Autism galore with zero remorse.
Jeyneko is a good friend,
If you want something lightweight and reliable, I recommend using an older version of Thunderbird, or the Opera Mail client in Opera 10/11/12. I personally use the basic HTML version of Gmail--it is a godsend for older browsers, and lightning fast on my P4.
Matt Tobin really dont like Roytam1 making his stuff work on Windows XP/Vista.Keep an eye out for Interlink from Matt Tobin (part of the Pale Moon team). His client looks and runs lean like Thunderbird 2x but has the ability of v52x.
Now it's only meant for Windows 7 and higher, but MSFN's Roytam1 has recompiled it for XP and Vista.
