Not ACPI Compliant
I made no changes to my computer whatsoever, but suddenly I get this BSOD when I startup in the morning, telling me that my BIOS is not fully ACPI Compliant. I leave the BSOD on for about 5-10 minutes, restart the computer, and voila! it works. This happens every morning for the past 3 months. I have the latest BIOS for my computer, and everything else seems to be working fine. No crashes during the day at all. Any idea how to fix this? Here's my system info:
OS Name Microsoft Windows XP Professional
Version 5.1.2600 Service Pack 3 Build 2600
OS Manufacturer Microsoft Corporation
System Name VAIO
System Manufacturer Sony Corporation
System Model PCV-RZ30CP(UC)
System Type X86-based PC
Processor x86 Family 15 Model 2 Stepping 9 GenuineIntel ~2393 Mhz
BIOS Version/Date American Megatrends Inc. 1010, 10/29/2004
SMBIOS Version 2.3
Windows Directory C:\WINDOWS
System Directory C:\WINDOWS\system32
Boot Device \Device\HarddiskVolume1
Locale Israel
Hardware Abstraction Layer Version = "5.1.2600.5512 (xpsp.080413-2111)"
User Name VAIO\SONY
Time Zone Eastern Daylight Time
Total Physical Memory 1,536.00 MB
Available Physical Memory 778.81 MB
Total Virtual Memory 2.00 GB
Available Virtual Memory 1.96 GB
Page File Space 3.36 GB
Page File C:\pagefile.sys
Courtesy of Jose Ibarra
Download BlueScreenView from here:
http://www.nirsoft.net/utils/blue_screen_view.html
Unzip and run it (BSV installs nothing) and let it finish scanning all your crash dump files.
If you double click on of the dumps, you will get some information about it (including the Caused By Driver field) and you may be able to spot the problem right away - especially if you see a pattern in the dumps where the Caused by Driver field is the same (start with that driver).
BlueScreenView tries to locate the right driver or module that caused the blue screen by looking inside the crash stack. However, be aware that the driver detection mechanism is not 100% accurate, and you should also look in the lower pane, that display all drivers/modules found in the stack.
Sometimes BlueScreenView will implicate XP files as the cause of the crash (ntoskrnl.exe, win32k.sys, hal.dll etc.) but they are probably not the real cause of the crash (BSV does the best it can) and you need to look at some other crash dumps or use the Windows debugging tools to dig a little deeper into the crash dump to find the real cause.
Select (highlight) one or more of the most recent dump files by clicking them and holding down the Ctrl key to select multiples files. Try to select just the most recent ones that relate to your issue (maybe five or so dump files to get started).
Click File, Save Selected Items and save the information from the dumps to a text file on your desktop called BSOD.txt.
Open BSOD.txt with a text editor Notepad, WordPad, etc.), select all the text (Ctrl-A), copy all the text to the Windows clipboard (Ctrl-C) and paste the text from the clipboard (Ctrl-V) back here in your next reply.
Here is an example of the BSV report from a single BSOD that I initiated on purpose that shows the cause of the crash as the i8042prt.sys driver belonging to Microsoft Corporation:
Dump File : Mini102911-02.dmp
Crash Time : 10/29/2011 4:54:36 AM
Bug Check String : MANUALLY_INITIATED_CRASH
Bug Check Code : 0x000000e2
Parameter 1 : 0x00000000
Parameter 2 : 0x00000000
Parameter 3 : 0x00000000
Parameter 4 : 0x00000000
Caused By Driver : i8042prt.sys
Caused By Address : i8042prt.sys+27fb
File Description : i8042 Port Driver
Product Name : Microsoft® Windows® Operating System
Company : Microsoft Corporation
File Version : 5.1.2600.5512 (xpsp.080413-2108)
Processor : 32-bit
Crash Address : ntoskrnl.exe+22f43
Stack Address 1 : i8042prt.sys+27fb
Stack Address 2 : i8042prt.sys+2033
Stack Address 3 : ntoskrnl.exe+6e715
Computer Name :
Full Path : C:\WINDOWS\Minidump\Mini102911-02.dmp
Processors Count : 4
Major Version : 15
Minor Version : 2600
Dump File Size : 94,208
Send the BlueScreenView information from the last 5 memory dumps (if you don't have 5 memory dumps yet, send the most recent ones you have).
While you are waiting, please do this:
Perform some scans for malicious software, then fix any remaining issues:
Download, install, update and do a quick scan with these free malware detection programs (not at the same time):
SAS will probably just report a bunch of tracking cookies that you can delete.
They can be uninstalled later if desired.
Reboot your computer and troubleshoot remaining issues.
Sometimes it is easiest to just upload the memory dump files from your most recent crashes to your SkyDrive (everybody has a SkyDrive for sharing file). Then somebody that already has the Windows debugging tools can take a closer look at things and figure out what is going on.
The memory dump files from the recent crashes and BSODs are usually in this folder:
c:\windows\minidump
The files will be named something like this:
Mini120311-01.dmp
You need to upload the most recent ones... maybe 5-10 of the most recent crash dump files ought to be enough if you have that many. If you do not have that many, send what you do have.
No Crash Dump
Thanks for your detailed reply, but I do not have any crash dump files. The scan came back negative. I checked in the Windows directory, and there isn't even a folder called minidump. By the way, I took another user's advice and changed the CMOS battery, but it seems to have made the problem worse. Where I used to have to wait only 5 minutes with the BSOD and then restart, now it takes about 30 minutes. Go figure. Also, now my USB hub is no longer automatically recognized. HELP!!
Malware Scan
Malware scan seems to have found nothing, I've copied the results below. By the way, I have an image disk from my original install (many years ago), and I reload my entire system (it's on a separate drive) about once a week. So I doubt it's any software problem.
Scan Date: 9/16/2014
Scan Time: 10:31:48 AM
Logfile:
Administrator: Yes
Version: 2.00.2.1012
Malware Database: v2014.09.16.04
Rootkit Database: v2014.09.15.01
License: Trial
Malware Protection: Enabled
Malicious Website Protection: Enabled
Self-protection: Disabled
OS: Windows XP Service Pack 3
CPU: x86
File System: NTFS
User: SONY
Scan Type: Threat Scan
Result: Completed
Objects Scanned: 261097
Time Elapsed: 17 min, 0 sec
Memory: Enabled
Startup: Enabled
Filesystem: Enabled
Archives: Enabled
Rootkits: Disabled
Heuristics: Enabled
PUP: Enabled
PUM: Enabled
Processes: 0
(No malicious items detected)
Modules: 0
Registry Keys: 0
Registry Values: 0
Registry Data: 2
PUM.Disabled.SecurityCenter, HKLM\SOFTWARE\MICROSOFT\SECURITY CENTER|AntiVirusDisableNotify, 1, Good: (0), Bad: (1),,[ba9aa24c186359ddcece47b345bf817f]
PUM.Disabled.SecurityCenter, HKLM\SOFTWARE\MICROSOFT\SECURITY CENTER|UpdatesDisableNotify, 1, Good: (0), Bad: (1),,[55ff32bc215a3204108e9961f50f4cb4]
According to Sony, I have the latest BIOS. (When I went to AMI, they sent me to a paid service which claims that there is an update). Anyway, how could it be a BIOS problem if I changed nothing on my computer in the past year (and I only started having the problem a few months ago)? As far as the minidump is concerned, I had the settings right, but it was not producing any. And again, the computer works, just I have to sit and wait until it starts up. I never have crashes during the day. I am inclined to believe that the mobo is going, but even that would be odd.... Any ideas?
how much free space do you have??
what is the page file set at?? system managed is best for now.
You stated that you had changed the cmos battery.
as per this link your bios is correct
doing some more searching at this time, and I see that you have this same question posted in a couple of other forums. :)
Also, a couple of more questions
does it occur after a shutdown?? or only after a restart??
I want you to run checkdisk to see if this will help, but generally checkdisk works on the disk and file system, but it can not hurt
How to perform checkdisk
go to start, run, type in cmd
type exit and press enter
note, it may have to run twice if any errors are found, run until no errors are found.
note it is better to run chkdsk from the recovery console, if you want instructions to burn a recovery console to a cd, let me know.
OK. My system disk is 66% empty, and my files disk is 15%. My paging file is 2048M. Note even when I start up from a CD, with the HD disconnected, I get the same error. It only happens after the computer has been shut down over night. I can restart it, or even shut down and manual restart, during the day without a problem. It seems like the computer has to be "heated up" for the computer to start without the BSOD. It's really odd. And yeah, I've posted on other forums, but none has been responsive as you. Thanks a ton. I'll try the checkdisk tonight, but I doubt it'll solve anything since the HD is not the problem as stated above.
Disable the automatic restart
Right-click on Computer, select Properties - Advanced System Settings - Advanced tab - Startup and Recovery- settings System Failure uncheck the box.
The read the BSOD stop code and write it in here (what's after Stop: 0000000x....etc
A) I am guessing it may be a hardware failure.
1) A capacitor on the motherboard or several of them have failed such that they cannot hold charge. It takes some time to recharge and become fully operational after you start your computer.
2) CPU fan is not starting at the first attempt.
B) I am guessing it may be software problem. A cold bootup failure.
I was having a similar issue. I updated my BIOS several times until my motherboard stopped doing it. I have P7P55D and Intel i7-860.
Both above quotes are from here
I agree with the 1. cause, since it runs fine after heating up, therefore you may have to replace your motherboard, however, it has to be the exact same motherboard from the manufacturer, or there will be an activation problem with your os, (but since you have an image to reinstall, this might not be the case), You can get it activated,you will just have to do it by phone, as your product key is tied to the pc/motherboard if it came preinstalled.
or you could take it to a shop that has the capability to see which item on the board is failing and they can just replace that particular diode/capacitor/resistor/etc...
short of getting a new motherboard, I can not think of anything else, personally I leave my pc on 24/7, that would at least eliminate the bsod.
however, did you disable automatic restart and did you ever get a bsod that you could read the stop code?? the bsod generally will show what driver is bad also.
