http://forums.techguy.org/windows-xp/1124932-no-sound-my-pc-xp.html
is the above your link also??
to be clear you cannot get msinfo32 to run on the bad pc??
I do not need it from a working pc, just the one with no sound.
what happens when you type in msinfo32??
do this:
First. Set Hidden files and folders to display.
Start | Settings | Control Panel | Folder Options | View tab
Check:
? Display the contents of system folders
? Show hidden files and folders
UNCheck:
? Hide protected operating system files
Apply | OK
[[Hidden files and folders will appear dimmed to indicate they are not
typical items.]]
Second. Paste this in the Start | Run box...
C:\WINDOWS\PCHealth\HelpCtr\OfflineCache
Click OK.
Look for a file called index.dat. Is one there?
if not go here and download it and put it in above folder
https://onedrive.live.com/?cid=d7389b68b3a275ad&id=D7389B68B3A275AD!120
this is my onedrive, used to be skydrive. scroll down to index.dat and download to desktop.
What I am looking for is the manufacturer and model number of the memory currently installed in the no sound pc.
also here is a program to test your sound card
http://www.passmark.com/products/soundcheck.htm
