Need Audio Driver for CQ60-615DX (SP3)
Discussion in 'Windows XP Drivers' started by JingleXP, Nov 20, 2016.
  1. JingleXP
    JingleXP
    Allison Park
    I need an audio driver for Windows XP Pro SP3 on Compaq Presario CQ60-615DX. None of the ones I found work. The closest to working was a driver that played nothing from speakers, but it did play out of headphones at a lower pitch (To me, no sound is like broken glass, wrong speed/pitch is like 1,000,000 glasses broken)
    UPDATE: Device Instance ID - HDAUDIO\FUNC_01&VEN_14F1&DEV_5067&SUBSYS_103C360B&REV_1003\3&C39D3AE&0&0001
  2. JingleXP
    Elizabeth23, Nov 21, 2016
  3. JingleXP
    JingleXP
    Allison Park
    Orig. OS is Win 7, I multibooted XP, 7, and 10. I believe I have tried that driver, but I will try again when I get home at 3PM.
    JingleXP, Nov 21, 2016
  4. JingleXP
  5. JingleXP
    JingleXP
    Allison Park
  6. JingleXP
    https://www.lifewire.com/how-to-fix-code-10-errors-2623181
    read through above, if after a couple of restarts you still get the error, lets see if we can download a driver for vista, sometimes what will work for vista will work on xp since your pc was not made for xp.
    http://h20564.www2.hp.com/hpsc/swd/public/detail?swItemId=ob_47262_1
    above is the driver for vista, see if that works. if not we can try something else, :)
    EDIT:
    http://www.techsupportforum.com/for...gh-definition-audio-driver-for-xp-463577.html
    a couple more driver links are listed in the above thread
  7. JingleXP
    reply no 2, one of the threads in my last reply said to install device manually through device manager, go to device manager and choose scan for hardware changes and let it find the audio card, and then point the install dialog box to the desktop where you have the driver downloaded to.
  8. JingleXP
    JingleXP
    Allison Park
    Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
    Driver used was link by makinu1der2, other drivers and Vista driver produced code 10, solutions didn't work
  9. JingleXP
    Elizabeth23, Nov 22, 2016
  10. JingleXP
    JingleXP
    Allison Park
    JingleXP, Nov 22, 2016
  11. JingleXP
    JingleXP
    Allison Park
    The pitch is normal if I watch YouTube, but it changes after I close it out.
  12. JingleXP
    glad it worked but this is as far as I can go, do not know how to adjust the pitch, unless you go to the audio properties, (right click on the volume icon and choose adjust properties or choose open volume control. :)
    let me know if adjusting the properties works, :)
  13. JingleXP
    JingleXP
    Allison Park
    Thanks, the sound has stabilized to a somewhat proper pitch, which is OK for me.
    UPDATE: I have to keep Firefox open to work, but thanks anyway!
    JingleXP, Nov 23, 2016
  14. JingleXP
    not sure why Firefox has to be open!
    Elizabeth23, Nov 24, 2016
