Memory Question
Discussion in 'Windows XP Help and Support' started by Elizabeth Siegle, Jun 29, 2018.
  1. Elizabeth Siegle
    Elizabeth Siegle
    I have a IBM Thinkpad I use for work. I had issues yesterday, that seemed to be memory related. Very slow response, MS Office freezing at opening. Very unusual behaviors for this laptop! Today, I looked at the Control Panel/System, and it shows 3G memory. I checked the BIOS... 4096 memory recognized. I popped both chips, re-seated them. Still 4096 in BIOS, 3G in System. Am running repair for Office, since it appears to be corrupt, now. Any suggestions about the difference in memory registering??
    Thank you for ANY ideas!!
  2. Elizabeth Siegle
    WindowsXPforever
    Do you have any programs that runs in the backround?
    WindowsXPforever, Jun 29, 2018
  3. Elizabeth Siegle
    Elizabeth Siegle
    Thank you for the reply! Yes, and they have always been there. The biggest mem hog is the antivirus. I disabled it - I am ONLY on WiFi with that laptop from home, and that is a direct connect to another computer... not the internet. (No worries is what I am saying) That did NOT change the lag. This lag is literally 30 hours old. Began yesterday at 7AM my time. Never had issues with this laptop like this.
  4. Elizabeth Siegle
    WindowsXPforever
    Maybe scan with your antivirus maybe there is a virus.
  5. Elizabeth Siegle
    Elizabeth Siegle
    I ran the antivirus, and it came back clean.
    Any idea as to why the Control panel says 3G, and BIOS says 4G?
  6. Elizabeth Siegle
    read HERE on the issue of 3 vs 4 gb of ram
    is the lag happening in safe mode? safe mode with networking?
    you should install malwarebytes free and run that to see if malware has infected your pc
    what is using the most ram, you can see in task manager which program or service is running.
    Elizabeth23, Jun 30, 2018
