MATROX Graphiccard/CaptureCard to leave for low, only works on XP
Discussion in 'Windows XP Hardware' started by JanTulpe, Oct 27, 2021.
  1. JanTulpe
    JanTulpe
    I hope I may post this here, otherwise pls delete and inform me, thanks.
    Matrox RTX100 Xtreme Real Time PCI Capture Card with Breakout Cable
    P/N: RTX100/KIT/NX
    Specs
    Interface Provided
    lType : IEEE 1394 (FireWire), audio, display / video
    lInterface :
    S-video input, S-video output, composite video input, composite video output, line-in, line-out
    lConnector Type :
    4 pin mini-DIN, 6 pin FireWire, RCA, mini-phone stereo 3.5 mm
    Miscellaneous
    lIncluded Input Adapter Accessories : breakout box
    Video
    lType : video capture adapter
    lForm Factor : plug-in card
    lDigital Video Format : MPEG-2, DV, DVCAM
    lVideo Compression Format : YUV 4:1:1, YUV 4:2:0
    lInterface Type:
    S-video input, S-video output, composite video input, composite video output, IEEE 1394 (FireWire)
    lAnalog Video Signal : S-Video, composite video
    lAnalog Video Format : NTSC, SECAM, PAL
    lAudio Input Support : Standard
    lAudio Sampling Format :Stereo 16-bit / 48 kHz
    lImage Recording Format :BMP, TIFF, TGA, GIF
    lFrame Rate :
    NTSC: 30 frames per second, PAL: 25 frames per second, SECAM: 25 frames per second
    lDigital Video Capture Resolution :720 x 480, 720 x 576
    Software / System Requirements
    lPeripheral / Interface Devices : CD-ROM, PCI slot, graphics card, sound card
    System Requirements
    lOS Required : Microsoft Windows XP Home Edition, Microsoft Windows XP Professional
    lAdditional Requirements : CD-ROM, PCI slot, graphics card, sound card
    l
    Header
    lBrand : Matrox
    lProduct Line : Matrox RT.X
    lModel : 100 Xtreme Pro Suite
    lPackaged Quantity : 1
    lCompatibility : PC
    System Requirements Details
    lOperating System : Windows XP Home/Pro
    lProcessor Type : Pentium 4
    lProcessor Speed : 2.4 Hz
    lMin RAM Size : 512 MB
    lMin Hard Drive Space : 500 MB
    Slot Required
    lType : PCI
    lForm Factor : three-quarter-length
    lTotal Qty : 1
    Wenn gewünscht, können Sie das passende Adobe Premiere Programm mit dazu bekommen, gegen einen kleinen Aufpreis.
    Funktioniert einwandfrei, Privatverkauf, kein Umtausch/Rückgabe/Wandlung
  2. JanTulpe
    I no hablo espanol.
    ClippyBeer, Oct 27, 2021
  3. JanTulpe
    JanTulpe
    I also do not... :) Can I help you in some way?
  4. JanTulpe
    Madeleine Takam
    Alderley Edge
    Guten Tag
    Sie befinden sich wahrscheinlich im richtigen Teil des Forums. Ich schlage jedoch vor, dass Sie Google Translate verwenden, und ich empfehle Ihnen auch, den gewünschten Preis anzugeben. Aber ganz ehrlich, hätten Sie nicht eine viel bessere Antwort von ebay?
    Madeleine Takam, Oct 27, 2021
    Mr Siamese Cat likes this.
  5. JanTulpe
    JanTulpe
    Hallo Frau Takam, mit dem Punkt Ebay haben Sie normalerweise sicherlich recht, jedoch benutzt kaum noch jemand Win XP, für andere Betriebssysteme eignet sich die Karte nicht - ich hoffe hier eventuell einen Interessenten zu finden für eine damals sehr teure, innovative, anspruchsvolle und hochentwickelte Technik, die ich jahreland sehr gerne benutzt habe. Zum Wegwerfen ist sie zu schade, vllt freut sich ein XP-Enthousiast darüber.
    Preis - werde ich gleich vermerken, vielen Dank!
    Google - Translator - Der Text stammt vom amerikanischen Datenblatt des Herstellers Matrox - englischer wird's Goggle kaum können denke ich!?
    Vielen Dank für Ihre aufmerksame Zuschrift.
    mfg Jan Tulpe van Oranje
    Madeleine Takam likes this.
  6. JanTulpe
    JanTulpe
    Aber Frau Takam, vllt könnten Sie mir sagen WIE ich den Beitrag ändern kann, ich finde nirgends einen "Edit" Button - denn ich sehe erst jetzt, dass noch ein deutscher TextTeil drunter steht, denen meinten Sie wahrsch nehme ich an...
  7. JanTulpe
    Madeleine Takam
    Alderley Edge
    Hi Jan
    I have just logged in myself and I can’t find where to edit posts either. I am positive one could at one time; Because I have edited posts in the past. It can’t be because you are a new member, because I have been a member for 18 months now.
    I will see if I can edit this new post and I will also let Ian the administrator know, if I can’t.
    All the best
    Madaleine
    Hallo Jan
    Ich habe mich gerade eingeloggt und kann auch nicht finden, wo ich Beiträge bearbeiten kann. Ich bin mir sicher, dass man es einmal könnte; Weil ich in der Vergangenheit Beiträge bearbeitet habe. Es kann nicht daran liegen, dass Sie ein neues Mitglied sind, denn ich bin jetzt seit 18 Monaten Mitglied.
    Ich werde sehen, ob ich diesen neuen Beitrag bearbeiten kann und werde Ian auch den Administrator informieren, wenn ich es nicht kann.
    Alles Gute
    Madaleine
  8. JanTulpe
    Madeleine Takam
    Alderley Edge
    Hi Jan - - - Again
    It seems I can edit my latest post, but not my previous one.
    I probably mis-remembered, how one edits posts.
    Perhaps it is best to put up a new post and write out in English all the way through.
    You need to stress this card is a PCI only, although people with older Workstation boards will be able to use a PCI-X slot.
    Hope this helps
    All the best
    Madeleine
    Hallo Jan - - - Nochmal
    Es scheint, dass ich meinen neuesten Beitrag bearbeiten kann, aber nicht meinen vorherigen.
    Ich habe mich wohl falsch daran erinnert, wie man Beiträge editiert.
    Vielleicht ist es am besten, einen neuen Beitrag zu erstellen und vollständig auf Englisch zu schreiben.
    Sie müssen betonen, dass es sich bei dieser Karte nur um eine PCI-Karte handelt, obwohl Benutzer mit älteren Workstation-Boards einen PCI-X-Steckplatz verwenden können.
    Hoffe das hilft
    Alles Gute
    Madeleine
