looking for DICOM viewer for XP 32bit - like Pro Surgical 3D
Discussion in 'Windows XP General Discussion' started by Mr Siamese Cat, Nov 30, 2021.
  1. Mr Siamese Cat
    Mr Siamese Cat
    Glossop UK
    I am looking for a good DICOM viewer for XP 32bit, something like Pro Surgical 3D. I have tried Sante DICOM Viewer 3D Pro, but it is not compatible with XP. I have course used the original Dicom Viewers that came with the original MRI Scans, but it isn’t good at handling the DICOM directories.
    Bizarrely DroidRender for Android is the best lightest and most compatible with all DICOM -MRI Scans and directories, but pretty pointless on a Samsung Galaxy Note 20 Ultra. Anything less than a 40” monitor with good graphics card is a waste of space, so it has to run on XP
    Please only make suggestions if you have actually used the software you are recommending.
    Thanks
  2. Mr Siamese Cat
    red Guest
    go take a look around the internet archive ( cd rom images or software) there is a mine of stuff waiting to be found also known as the way back machine
    long live xp :)
    red, Dec 1, 2021
  3. Mr Siamese Cat
    red Guest
    [​IMG] also try here
    red, Dec 1, 2021
