The position is as follows.
I got a message on a web site that i often visit, to update Java.I dont have Java ,so downloaded that.It did not solve the problem.I then decided to use YAC(yet another cleaner) which i used before, but forgot about it.That did the trick.
However,i now have another problem.I have a  message which shows before i open Outlook Express
ie The instruction at XXXXXXXXXXXX referenced memory at XXXXXXXXXXXXX.The memory could not be written.Click ok to terminate or cancel to debug the program.
By the way the Anti Virus i use is AVG.
Elizabeth23  i have recorded the two web sites you have recommmended.
