Hello. I'm currently trying to install Windows XP, but there's a problem. Im currently using a HP Windows 7 computer. I put a Windows XP installation disk and installed Windows XP. But when im trying to copy files, a message comes up saying that it cant copy a certain file. Press ENTER to retry, and Press ESC to skip it. No matter how many times I press "ENTER" retrying doesnt work, so I am forced to skip the file. Once its finished copying the files, it goes to the Windows XP setup. But then it says "One of the components that windows needs to continue setup could not be installed"
I dont know what to do because I cannot install those certain files.
What should I do?
What should I do?
