I need a SM Bus controler for XP
Discussion in 'Windows XP Drivers' started by WindowsXPforever, Apr 25, 2018.
  1. WindowsXPforever
    WindowsXPforever
    CAN SOMEBODY HELP ME FIND IT?
  2. WindowsXPforever
    need make, model, and model number of pc, or the motherboard number and manufacturer to insure the correct chipset driver
    Elizabeth23, Apr 25, 2018
  3. WindowsXPforever
    WindowsXPforever
    1.Display adapter(Intel 82945g Express Chipset Family)
    2. Made in 2006
    3.Computer (TAC)
    4 mOTHERBOARD Intel desktop board e210882
    5 ram 1,99
    WindowsXPforever, May 2, 2018
  4. WindowsXPforever
    WindowsXPforever
  5. WindowsXPforever
    Elizabeth23, May 2, 2018
  6. WindowsXPforever
    WindowsXPforever
    Here? I think i don't see it
  7. WindowsXPforever
    download the .exe on the left and it should install if it does not it will tell you it is incompatible and I will search again.
  8. WindowsXPforever
    WindowsXPforever
    OH OK I WILL SEE
  9. WindowsXPforever
    ok will check back in a few minutes
  10. WindowsXPforever
    WindowsXPforever
    Thanks @Elizabeth23 it installed! You realy helped me!:)
    trimis likes this.
  11. WindowsXPforever
    glad it worked, :)
  12. WindowsXPforever
    Vineet Garg
    Vineet Garg, May 5, 2018
