Hi folks,
Not long ago I got an old PC without HDD on it. For testing it I used a HDD from another same age old PC (different brand and MB) which has a Win XP installed. Surprisingly it could start up the Win XP in the normal boot mode. As expected, It didn't go well since there were a lot of errors caused by the hardware compatibility. After the test I put the HDD back to the original PC and then I always get a blue screen error (stop: 0x0000007E (0xC0000005, 0xB3871756, 0xBA4C742C, 0xBA4C7128)) when it boots into the normal mode of the Win XP. It is now able to start up in the safe mode only. I tried to use the original installation disc to repair it but doesn't work. Is that possible to fix this problem without re-install the OS? Thanks!
