help-virus
hello,
i cant find anything on line for this.
i boot up my laptop (im on a desk top) and only icons show up. no text. i try to con/alt/del to see what activity there is but its a different screen and no text. i tried to go online to try a virus scan and i cant get on. I tried to connect hardwired to the network but nothing.
any suggestions?
I'm not signed up to do Malware logs here but i have been for 8 yrs or more over at G4 Tech support
install an antivirus software like kaspersky on your laptop and scan full computer it will find remove virus from your computer.
burn a cd with Hiren's boot cd, get your data backed up and wipe your drive and reinstall.
Courtesy of Jose Ibarra:
http://www.hirensbootcd.org/download/ (look near the bottom of the page, do not click on any ads).
http://rufus.akeo.ie/
http://www.hiren.info/pages/bootcd-on-usb-disk
Hiren’s for flash drive
