Modern OS have Pure-Ref & others for click-through trans ghosting...But what for XP?
Ghost-It is a good one... It produces a transparent window of selected image at a level of trans you select then the window is 'frozen' in place & you can work underneath it in 'click through' style...
Tons of uses for comparison of shape-size but most common is to have a ref image above a 2D or 3D app that does not have ability to import a reference image... Like say if you wanted to pixel paint someone or thing in MSpaint or other & wanted to trace out features...
Here you see ghosted image it is 'click through' & you can work underneath...There is a tray icon you use to reset the image, trans or other-
Handy to have...
Here is the main page on the wayback-
https://web.archive.org/web/20021105162306/http://home.rochester.rr.com/artcfox/GhostIt/
And here is the DL Page-
https://web.archive.org/web/2003012...ochester.rr.com/artcfox/GhostIt/Download.html
Handy to have...
