Putting together a Fruity package... Not quite ready yet but since the thread will be rather intensive might as well get started...
OH, did a tune today in it to test out the workflow, pretty easy... If I can do it you can do it-
https://alonetone.com/TalkOrBell/tracks/beating-on
Here's the screen-
Also first time using EZ-BeatCreator to slice up a loop then it loads each slice in on a separate channel... Then it acts like a REX file you can change the tempo without changing pitch... Neato!...
Pretty much finished testing VSTs I recently found these which are VST1 as Fruity 2.7 cannot use VST2-
Voxengo StereoTouch is awesome, using it alot however plugs with interfaces cannot have events automated but most GUI-Less VSTs can & I have tested damn near 600 of them but only a small amount are VST1, but still plenty...
BTW, Fruity Tracks 2.04 will be included as well & one can simply copy the VSTs over to it-
All working good in XP but one should change compat mode to windows 98 otherwise there will be a 'FilterData' error when trying to open select for plugins & the plugins menu will be all blanked out...
The DX plugs pickup where the VSTs leave off, there are a bunch & haven't finished testing... These are quality plugs from yesteryear all thrown out & forgotten & man they were expensive back then just the Waves Gold Bundles was $1,300.00 back then & many other singulars in the 100-300 dollar range...
Here's showing editing of events in a GUI-Less plug-
Here are some of the Waves DX plugs-
The VB Plugs have a stacker where you can add up to 16 DX plugs into a single slot space-
Sonic Madness... More to come>>>
Here's the screen-
