Dual Boot Problem ?
Discussion in 'Windows XP Help and Support' started by AlminAgic, Nov 16, 2013.
  1. AlminAgic
    AlminAgic
    when i start my Computer I get three Options
    Windows XP Professional TuneUp Backup
    do i need to delete something or ?
    [boot loader]
    timeout=30
    default=multi(0)disk(0)rdisk(0)partition(1)\WINDOWS
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional (TuneUp Backup)" /noexecute=optin /fastdetect /TUTag=2UDEXW-BAK
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /noexecute=optin /fastdetect /TUTag=2UDEXW /Kernel=TUKernel.exe
    multi(0)disk(0)rdisk(0)partition(2)\WINDOWS="Microsoft Windows XP Professional" /NOEXECUTE=OPTIN /FASTDETECT
  2. AlminAgic
    Yes, go to start, run, type in msconfig and press ok, in msconfig click on the boot.ini tab and click on the button that says check all boot paths. if it states a path is bad you can delete it.
    Have you done any kind of repair install ? or attempted to install windows over an existing windows?
    below is an example of some boot samples:
    A typical simple example
    [boot loader]
    timeout=30
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Microsoft Windows XP Professional" /fastdetect
    Example with Recovery Console as an option
    [boot loader]
    timeout=30
    [operating systems]
    C:\CMDCONS\BOOTSECT.DAT="Microsoft Windows Recovery Console" /cmdcons
    Example with Safe Mode as an option and "timeout" =10 seconds
    [boot loader]
    timeout=10
    [operating systems]
    multi(0)disk(0)rdisk(0)partition(1)\WINDOWS="Safe Mode" /safeboot:minimal /sos /bootlog
    Elizabeth23, Nov 19, 2013
