You can use a program like Revo Uninstaller, but you have to be careful to check all the registry entries to be sure they refer to just the program you are uninstalling.
what I like to do is use find in regedit and delete the entries myself. and I do a search through my pc with all hidden files unhidded for the program also. Lots of programs leave remnants, and some leave a driver behind, you would go to device driver and look at the hidden drivers to see these.
when you say no success on restore, do you mean you could not run a system restore or that when you restored the problem did not go away???
run the following to insure that you are clean:
make sure you get the free one and check each page before clicking next to insure that you do not install any added software:
Malwarebytes Free (MBAM):
http://www.malwarebytes.org/products/
SUPERAntiSpyware: (SAS):
http://www.superantispyware.com/
you might want to check with AVG to see if it is still supporting xp, I personally would not use AVG, but it is up to you.
I know that 360 Internet security by Qihoo is still supporting xp.
post back with results of cleaning.
in autoruns look for any program that you do not know what it is, and if you still cannot paste here then type the entry in so I can check it for you.
You can also look in event viewer to see if there are any errors about this issue.
