Desktop and start menu blank
Discussion in 'Windows XP Help and Support' started by lenrely, Apr 27, 2014.
  1. lenrely
    lenrely
    My desktop icons and start menu are gone and right-clicking the desktop is unresponsive. This includes safe mode so I can't run diagnostics, PC repair or goback. How can I access control panel or system utilities using task manager only, or is there an online product? Thanks.
  2. lenrely
    can you press ctrl + alt + del to bring up task manager, then go to file, new task and type in explorer.exe
    this should bring back the desktop, and then you should run some scans on your pc to insure you are free from infections
    Elizabeth23, Apr 28, 2014
