Delayed write failed
Discussion in 'Windows XP Help and Support' started by sony, Mar 13, 2014.
  1. sony
    sony
    Hi,
    In my desktop's system tray, i get the Windows error on and off at certain interval.
    On resuming after the power shut, this error is constantly popping.
    Attached herewith is the screenshot of the error that i am getting.
    Can anyone plz look into this and let me know what am i supposed to do.
    Thanks & Regards
    Sony
    sony, Mar 13, 2014
  2. sony
    Elizabeth23, Mar 13, 2014
  3. sony
    sony
    Hi,
    Thanks for this. After restarting the system, it works fine now. Disk check was skipped.
    Regards
    Sony
    sony, Mar 16, 2014
  4. sony
    okay, but if checkdisk needs to be run, you should run it with the /r parameter.
    Elizabeth23, Mar 16, 2014
  5. sony
    sony
    Hi,
    I meant when i resumed after the power shutdown, i skipped the disk check, hence the error.
    Now when i restarted the system, it works fine. I didn't have to run check dsk explicity.
    So all working well..
    Thanks
    Sony
    sony, Mar 17, 2014
  6. sony
    when an ungraceful shutdown has occurred, for example a power outage, it is always a good thing to run checkdisk to ensure that system files have not become corrupted due to improper shutdown.
    you can query the hard disk to see if it is dirty and the only way to clear the dirty bit is to run checkdisk, to query, go to start, run, type in cmd, and in the command prompt box type the bold text below:
    Examples
    To query the dirty bit on drive C, type:
    fsutil dirty query C:
    Sample output:
    Volume C: is dirty
    or
    Volume C: is not dirty
    Elizabeth23, Mar 17, 2014
  7. sony
    sony
    Hi Elizabeth,
    Thanks a lot for that information.
    I ran that command for drive C and it is "Not Dirty" at all.
    Cheers
    Sony
    sony, Mar 17, 2014
  8. sony
    okay, glad all is okay for you. :)
