Custom resolutions
Discussion in 'Windows XP Customization' started by Computer semi-expert, Jan 26, 2019.
  1. Computer semi-expert
    State of Confusion
    Does anyone know how to add custom resolutions to XP? My moniter has a native resolution of 1920x1080 pixels, but XP doesn't have it listed in the display properties.
  2. Computer semi-expert
    see attach: mine can go up to a higher number, but I do not use it I like 1024x728, when you go to display/settings, where is the slider positioned? mine is pretty far to the left so that I can get the setting I want, but I can slide it further right for higher resolution, and it shows it in the display/settings/advanced for the intel graphic settings box.
    Elizabeth23, Jan 26, 2019
  3. Computer semi-expert
    State of Confusion
    Mine doesn't go up quite that high (top is 1280x1024). I have it at 1280x768 because that is the highest widescreen resolution listed. I was thinking that there might be a file somewhere that I could edit to add custom resolutions.
  4. Computer semi-expert
  5. Computer semi-expert
    State of Confusion
    Elizabeth23:
    Could you create a zipped folder of the drivers on your PC and upload it? They will probably be at C:\dell\drivers.
    Thanks.
    Computer semi-expert, Mar 16, 2019
  6. Computer semi-expert
    Elizabeth23, Mar 16, 2019
  7. Computer semi-expert
    State of Confusion
    Sorry it took me so long to check this.
    My computer is a Dell Dimension 3000, otherwise I wouldn't have asked for your drivers, since they wouldn't have worked.
    Thanks a lot for the link.
    Computer semi-expert, Mar 29, 2019
  8. Computer semi-expert
    okay
    Elizabeth23, Mar 30, 2019
