control panel problems
I have 2 strange things happening with my control panel - 1. add/remove programs does not initiate at all, and 2. I have some other program icons appearing in the control panel window that I can't get rid of, such as Avira, Flash Player and Java. Any ideas?
you should first insure that your system is clean
1. what is your current antivirus?
2. do you have any other scanners installed?
3. do the following:
post back after scans are clean and we can further troubleshoot.
