Constant lag and BSOD on shutdown
laptop : hp pavillion dv8225nr
Ive had this laptop for years, a few years ago windows became nearly unusable due to lag. A Linux live CD told me the hard drive was failing. Recently i decided to replace the hard drive, but it doesnt really seem to have fixed anything, Even closing all programs and only opening 1 browser, i can not fluently stream a podcast, or watch youtube videos. The laptops old, but i did all those things on it before. Even while typing this 1 out of 10 buttons doesnt seem to register. Also, every time i shut down i get a BSOD saying:
bcmwl5.sys - Address F6D6E7CC base at F6D5C000, Datestamp 4e5ee1c0
*just read i might be able to fix that BSOD with a driver update*
Ive tested the RAM with memtest, a 17 hour test had no fails and i backed out of the test.
I dont know what else to do/check? any advice would be appreciated.
Also, i decided to install fedora linux on a 2nd partition to see if it ran correctly,
http://h10010.www1.hp.com/ewfrf/wc/...n&docname=c00307152&lc=en&swlinkmsg=100&tool=
this link said they could not find your product at hp
go to the above link and enter your info to try and find the correct driver
The file that is causing the problem bcmwl5.sys is a driver file for a Broadcom wireless device. I would suggest uninstalling the Broadcom device and remove all accociated software. Get the latest software\drivers from Broadcom (do this before uninstall if it is your only access to the internet). Then reinstall the device drivers and software.
from here:
http://answers.microsoft.com/en-us/...cmwl5sys/a57c1f1d-192d-4253-947a-dd0076d91333
once the blue screen is resolved we can work on the lag problem, which can be malware, defragment needed
what is your current antivirus?
do the following to insure a clean pc:
you will also need to run checkdisk, preferably from the recovery console, but if your install cd is only at sp2, and your os is at sp3, then run it from within windows.
go to start, run, type in cmd
type exit and press enter
this will take some time and the percentages will fluctuate, this is normal.
