Compiling MAME 2021?
Discussion in 'Windows XP Games' started by XPAnarchy, Sep 22, 2021.
  1. XPAnarchy
    XPAnarchy
    2-3 years ago MAME dropped support for XP because of it's frame being updated. However, there was someone who was compiling newer versions that ran on the OS. That apparently stopped a short time after it started.
    So my question is; is it still doable? Is there a reliable tutorial on how to do it?
  2. XPAnarchy
    krauzer
    You can download latest MAME for Windows XP here: LINK
    Just click on Télécharger MAME (XP) v0.xxx (xx.x Mo)
    That same link is updated whenever a new MAME is out.
    Thank you so much to the person who've been compiling it for XP all this time.
    krauzer, May 7, 2022
  3. XPAnarchy
    XPAnarchy
    The one thing I have trouble with is that when loading the rom, it won't let me hit a key to start any game.
    I can type in the search bar in the roms menu, but I can't seem to actually press any key to start a game. Not even the esc key will let me exit, so I have to use task manager every time.
    Whoever programmed this must've done something wrong or something cause this keyboard sure ain't working.
    XPAnarchy, May 8, 2022
  4. XPAnarchy
    krauzer
    Oh yes, I was having the same problem after 0.242, you can fix that by opening mame.ini in a notepad, and search for:
    # OSD INPUT OPTIONS
    keyboardprovider auto
    Just change from auto to dinput and save it.
    Then keyboard should work back again.
    EDIT: Just noticed you replied to my other thread. (LINK)
    krauzer, May 9, 2022
  5. XPAnarchy
    Mattpsu03
    Long shot, but does anyone have a link to groovymame (a newer version, say .236 or later) the 64-bit version that works with Windows XP 64-bit? The link to the XP 64-bit version from emu-france gives the “gettickcount64” error.
    Mattpsu03, May 24, 2022
