CodeBlocks 20.02 old 2024/2023 build
does anybody happen to have codeblocks 20.03 binaries dating back to late 2023? they've changed the files and it won't work on windows xp anymore (why would they even touch it?) I manage to track down a portable version that works I need the 32bit installers.
here is the portable 20.03 version that works on xp: CodeBlocks 20.03 windows xp
the one provided in the sourceforge is broken for Xp, the one in the web archive cannot be downloaded. it's ridiculous that they changed the build
You could try (somehow) building from source, but I'd consider that a last resort - working with legacy compilers and toolchains is one heck of a hassle.
https://forums.codeblocks.org/index.php?topic=23924.0
Are you allowed to use DevCPP in your environment? It worked like a charm for me.
Hi,
I have some 20.03 binaries last modified dates April 2020 to March 2021.
At the time I used them, I had to report a problem for which I was given a patch.
I seem to remember the it was needed to get the 32bit version running but at
the time the patch would not fix the 64bit version for XPx64.
Interestingly, the patch files are:-
14/10/2017 19:15 19,982 addr2line.exe
04/12/2016 06:13 1,231,000 dbghelp.dll
14/10/2017 19:15 29,198 exchndl.dll
14/10/2017 19:15 851,470 mgwhelp.dll
04/12/2016 06:13 128,152 symsrv.dll
26/07/2015 17:01 1 symsrv.yes
to be copied over after instalation.
Looking at the date of the binaries on sourceforge, my guess is that you need the patch files.
in theory there should be a link to them in the codeblocks forum, but I can no longer find it.
GOT IT
"https://forums.codeblocks.org/index.php/topic,23924.msg167864.html#msg167864"
